So far as I know, there's no available Dia-Fold hone (as would be used with the Magna-Guide) for recurves. There was a curved hone dedicated for use with the Aligner kit, but there seems to be some question as to whether it's available now (might be discontinued). If you can still find one, along with the Aligner guide rod, that might suffice as a supplement to the other kit. Even then, being that they use different guide rod setups, it may not be a perfect match (angle-wise) between the two. Overall, I like the Magna-Guide setup, and I use it pretty regularly. I'd still recommend it highly, for the vast majority of your sharpening needs. But for recurves, the flat and relatively wide Dia-Folds won't be ideal.
DMT does make continuous-surface curved hones, but they're not set up for use with the guided systems (and they're pretty pricey, as with most of the DMT continuous surface hones). I think Eze-Lap also makes several curved (elliptical) hones, also designed for free-hand use.
I used a Lansky kit a couple years ago, to reprofile my ZT-0350. Even then, I ended up finishing the recurve free-hand, with the Lansky hones. Those hones are narrower than the DMT hones, and that helped somewhat, fitting into the inside radius of the recurve. But, it was still not a perfect solution. Looking back, if I were to do it over, I think some wet/dry sandpaper wrapped or glued around a cylinder (PVC pipe, dowel, can/jar) is probably the simplest free-hand solution. If you're gearing up for stropping, it's the same technique. Edge-trailing stroke, done with light & easy pressure. This CAN be done with an edge-leading stroke too, same as sharpening on hard hones. But, it's easier to cut the paper that way too, so I'd recommend starting with edge-trailing. Take it slow, and I think you'd be surprised how well it works. Sandpaper is available in a very wide grit range too, so that really increases the versatility of this method for recurves (and any other blade).
