Sharpeners, for the record...
I have been reading through a bunch of posts regarding sharpeners and stones and decided on either a Lansky or a Sharpmaker system. It sounds like stones are great for the experienced hardcore folks, but I am neither of those. Before I order I wanted to ask for one last round of opinions based on my specific needs. I use a Scandi camp knife the most, but also have a number of good quality kitchen knives. So, which system is better based on these needs?
+1 vote for the Sharpmaker. Its only weakness is if the blades are too obtuse, but that's easily solved by leaning a cheap-o coarse hone against the rods and rebeveling using that.
Between these two, I'd choose the Sharpmaker, too, mostly because it is so much easier to use. However, the Sharpmaker offers only two angles -- 30 or 40 degrees. If your knife edges do not match these angles, you would need to reprofile or mess around by raising one end of the Sharpmaker block.
I use a GATCO kit. It is similar to the Lansky. The GATCO however offers 6 angles.
I have the GATCO professional kit. I have added a coarse diamond hone, an ultra fine hone and an ultimate finishing hone to my GATCO. I finish up with leather strops loaded with polishing compound.
The GATCO and I assume the Lansky are very easy to use and the learning curve is short.
I would definately recommend a rod guided system.
I use the Lansky myself and have the diamond hone set. I've used Lansky's for years and they work well for me. Like Hard H20 I finish on a leather strop using the green compound. A touch up on the strop will bring the edge back to hair popping sharp.
