Sharpeners Manko- SCORPION
Greetings, I present to you a slightly different device for sharpening knives. Professionals are kindly requested to give their comments regarding this system. Sharpening a knife with a constant angle along the entire length of the blade of any geometry.
[video]https://youtu.be/zvmGxb5caGM[/video] - Turbo sharpening
[video]https://youtu.be/19Mm18JHSws[/video]
2j1b5JB90UPC0P4lncg1h9JBdw_XemJeacojqCY2KRpB4-1H2cH8Y1O8vHuhwCCTWUvDA2ujrF3rPDYNi9k8RCvkxiJSmZ--pPGDuK6TyIBXt3L1L8oBWfFg2BvaXQksYMNcQQ70EDuK1JM_mX  IQ0X5l3HbRZvQmzmMGevLJfXZ3qFX8-dhVqg7xTmigJPU75T8rS4OzB4IGkrGTKOb7B7XYL62FElIrf_2  Wom99v7nTdGSoPEXY8x4k-zdn98tWEQTlZGkE3kFPld0zXNsglGScnNYcd8mCSoLCczFnu5X  xC7xy--fUMEC3DuxbbIiitN1m4CymBx-kC-qjLPti_eyaF59Nr-d3ztFlyozW8kDlID5OG1MDC59W3TqdA4wgKq1Ps_XO4jlf4WDQ  AwK4TXF1SHqY25jZn1AcYbCbP9f7victB69AY5pffwrEZakesx  hCGOOjzt8dHRXHeZcUxYppinqp_148eTbmYXyJRmyOSshUbs3r  Y4Xv9uIdckh2AmcR6whVMHTrKFnw0kbdiMkxTiWFr9u8K87nVz  yM838=w890-h667-no
4l8pQ7igKWNWuv_P8ies5DDsmDJ0N1UUQUOBxrfHNwcYjimyM7  VJ4aF6BI5t55WqIaZYeSbO9-zCZNMNgFnntvh-CB1iJTU1B5o0biZE4PINMAmiIPgap2XSBZ3EWWtSzG3SsrYs2b  ndNzggbeUJgDaSqn3_foyS6BlRXJkK2DczJWDHZu8IN29sdmTw  qulhDC7Tt_9VlFx6VPaNXC-2EbMTL-owPpWrIEV007iVhHN7DW3wF8EMzmLtVuEBDccTDr7bCCAqeQJa  Fv4e6iizTFp4i17EdfORGyGkHhPQTX6eL0M9A9DI66MEA8QAiI  i10fLEqo9JQbRyBfABvdA07XR3q9zCvnrC3WQ1xd6vwSocx68u  8OGBX1fQZh0EOjAhBJs2P79j7UKSivrkHK8QSceh2LHFMOQ3ia-vB2X38XuZ2M6Coug-f4bAaUoMV0ZM-M6gZ7zr06_2oJkhVUj3q_Zf2Z-2d9dRlpFnbbLJvhZwbJPjXmfmoeQ3y6VHPrKhNWLTRqVrmEWMB  xQ2RiIGhb_WcAJ6-oBiWTLw8S2PLsA=w890-h667-no
IuFyade_gVPtt5RVfUwIfKpEe--0RuSg6aNqkoZwhRyHVwMaFxNH6YZDrVFJsDzqZ59-o2-tRHMUV-aRn028aQ9cnuW9-ZF8p_MjcZcvE047hq5xLdukgab6lpZc0I6vLFpEZWTAmvaJV-cNGSGF1XGEmt9Ii8yv2gu43202lL014Cw-EPcyKatatVPCCk-OhIlYzuURunW8h7EGHEWET_nZ8BrY4D38_E67P_UtZQjV8Pzj2  EBh_c2Nzmt_pXAg9ip-5IhOog0HnAxOX1WQn3Dzo3DaoJ5osV4a1i6EWFOAJ0iJBi-q1z3IB7ouobXWx4EybBFg3duxGYpAW0I3_XKpStiKc6Yo9n4Uv  m8NdRYJwmUUelp9qZcDtAZqFoUpeKth6_b-2DbaD0PIJQGRQb4ECTbVjKYPm6DSTQ_BQGG9qKBX6sdK-yOK_zYZBKYj9sv1fnxPLQARi_evmpZUTQ3bR7kMRtRxD8IqNa7  5PEzvyJ2uLc9wZSXFyi2oLLFF0jYzxL3b2tBolUsFvn3GowMCc  6nh3qLDdVUABN1lnao=w890-h667-no
kuQNmRBc4EDssASd19IilH94Ai27t2Ys5eFZH-QBDLppmVJKHU6i699A5lxmd_S0K37JRw2w3gi1rohAwVKZwE14  Qn35UEsW716yFyGOuTqteL180SlUQ7rYWhDiuhSBzXux6Nc_lV  ibTQtWrYxcwMCJSOZCMONCrgSPXHLig_6BdV55vnvxuNht_ntG  DAkXkuUKA2BWswqv_PBzlnhasnd68UqQhByuim2wOFuD2zUcup  rO_4_vJ3q775rjLr0i8n05nOfCQrFwM790Ujuvi1z0ymQAwskW  8WfARem8LsWLY-Tva4KQs6zd2aAfkIddlc-8yd5DUa4rmqV7dG5jcHSXzcwA-nNJIa7R9uFwIXLR0Ix2eoShqkpWvIrBAoPwY_K0U-tZAInzv7dbjY9Wu1YFbY8wJFkl-UnqNPCgrskY8FPpfBN5j2yHaiQro2uOXdFytjkAgHbjeExcDl0  By_87SZX4zApwtS4-QFg0DnlGYnUPgQOGYAiFONfGP1enL-sWVcTF9gukp0-9-usm8nuP5JH4ORg9k7LgjtXHJxw=w890-h667-no
The angle adjustment moves up and down on a spring while you are sharpening?
Forgive me for not reading the first thread but, this lack of angle control on the forward and back movements will lead to an edge that has ZERO consistency at the apex not to mention the bevel faces and shoulder.
It looks like a well build device but I again see a geometry issue with the moving blade clamp.
Lastly, put some rubber feet on that thing so it stops moving around.
Jason,
I was baffled by that at first also, then I read some more and looked more closely. The angle between the arm and the upright stays fixed after he tightens down one of the screws. However, the arm can move up and down vertically. So the angle is fixed, but the height is not. It still looks odd to see it moving, but I think the geometry is correct.
This is a complex machine and I haven't figured it out completely yet. It's interesting for sure.
YES: It does need rubber feet, or a rubber mat! :)
Brian.
Bgentry are correct, the angle are locked and the edge will, in this threads videos, be flat.
When the sharpener comes to the belly and tip the guide rod move slightly down becose those parts are closer to the pivot point, this means that the belly and tip will get the same edge angle as the straight part of the edge. This solution is very good - and new. Congratulations for that construction!
In the first thread, the first video, the tool are making a convex edge and the convex sphere seams to be about 3 degrees. This comes from the spring below the pivot point and thatvthe pivot point is not fixed (locked). This is a new solution for to make, and maintain, a convex edge. congratulatulations to that construction also!
The Scorpion is a interesting tool. The constructor have thought a lot on his construction!
The best thing, in my mind, is the possibility to make a flat edge in the same angle all along the edge witout any change of the edge angle.
The possibility to make a convex edge is good - but not perfect. The convex curve is not fixed. This means that the convex sphere will not be a 100 % perfect sphere. But - in the same time I do not think that is necesarry, The Scorpion will make a good convex sphere.
The man that construct the Scorpion shall have credit for the construction he has made!
Thomas
A well thought out design that addresses some of the challenges of rod guided knife sharpeners. I like the way the system has been built to compensate for distal taper; well done. As has been mentioned there's an obvious need for a none skid platform of some type.
I would be a little paranoid about the placement of my hand and digits relative to the oncoming sharp edge of the blade. I can see losing a knuckle or finger tip.
As someone who markets different sharpening fixtures I would be interested in price point on this tool. A PM is preferred.
Being an inventor myself I appreciate the effort you've put into your creation. Congratulations.
Regards, Fred
I like it. I think you've received some good feedback, most notably the name. "The Scorpion" sounds awesome.
I like your solution of clamping the blade at two points. Personally, I'd prefer the clamp to the table. I like that the angle will remain the same along the edge and differences in stone thickness are irrelevant.
It looks like The Scorpion can take advantage of readily available 1"x6" stones?
