I'm a freehand sharpener. I've never tried convexing an edge, the mousepad/sandpaper thing, etc. I had a biznitch of a time with Queen's D2 but found a simple solution. Part of it is above, doubling the factory edge bevel (actually I'm not 100% sure that's necessary on a new knife, but the one I had so much trouble with is a whittler that is ground back at least 1/16 from the original profile and thus the blade near the edge is darned thick). The other secret is to use a coarse carborundum stone. My grandfather had a kitchen-knife sharpening stone of carborundum that is about 12" long with a handle on one end. It is NOT the coarsest carborundum I've come across by a longshot, but quite a bit coarser than most arkansas, india, and the norton stones, much less the various ceramic stick sharpeners.
Pretty rapidly, that stone will put a shaving, coarse sawtooth edge on that D2 blade. Takes some work to polish it up on finer stones, but it can be done. The coarse, sawtooth edge isnt a terrific newsprint slicer, but a very useful and sharp edge.
One of the things about D2 that makes it so wear resistant is the presence of a lot of carbides in it. I have come across suggestions that when one tries to get a polished edge like you can get on 1095, 440, 420, etc., the carbides just fall out and keep the surface fairly rough by comparison. This is consistent with my observation that it is very hard to get D2 shiny.
Bottom line, you can get a very nice edge on D2. But it may be futile to try to get a polished edge like you can get fairly easily on more conventional steel.
