I'd just use the knife for a while, to become familiar (very) with how it cuts. A majority of factory edges are too conservatively thick (wide edge angle), and almost always would benefit from thinning the edge grind a bit. Sometimes you get lucky with a factory edge though, and it's best to use it for a while, so you'll develop a clearer idea of how (or if) you'd like to improve it. Jumping right into thinning a new edge, without first knowing how it'll change in performance, can sometimes be counterproductive. Having a clear picture (goal) of how you'd like to 'fix' it, based on what you've learned is lacking in it, usually produces better results in the end.
I also wouldn't necessarily take too much of the toothiness out of the new edge, until you see it's effect on what you're cutting. If done 'right' (fully apexed and burr-free), even very toothy edges can cut like demons; sometimes it's good to take advantage of it. In many of my own knives, I'm starting to put some bigger 'teeth' back into edges that I'd previously kept at pretty high polish. If you use your knife for cutting tough, fibrous materials (rope, carpet, heavy fabric, etc), a toothy edge can help with that. If most of your cutting tasks involve push-cutting (whittling/carving, slow & controlled cuts in materials that 'pinch' the blade and bind it), then a more polished finish will reduce friction and lend greater control with a lighter touch.
So, in a nutshell, don't rush into changing your new edge until you're convinced it needs it. At some point, you likely WILL change it (it's what knife nuts do, after all), but there's no reason not to see what it's capable of, beforehand.
If you touch it up at all, the one thing that many factory edges have is a slightly less-than-complete apex. It never hurts to examine the edge under magnification, to see if the factory stopped shy of fully apexing it, or worse, if they actually rounded off the apex in finishing it up. If so, it'll ALWAYS be improved by finishing what the factory didn't get done, and putting a crisp apex on it. Just doing that by itself will noticeably improve how it cuts.
David
I had a Benchmade Rift that came with a decent edge. It was super coarse though, even after I cleaned up the factory burr. I carried it a couple of days and quickly decided that I don't like coarse edges. Reprofiled and refined it on Norton India. Much better. To the person who started the thread, if you don't like the edge, you can try to refine it. Listen to bgentry though.
