When my Ti-Lite became dull, I had no luck sharpening it. So I painted the edge with a magic marker and saw that the Lansky stone was not hitting the edge of the right side of the blade.
My idea was to sharpen the blade first at 20 degrees per side and then finally sharpen it at 25 degrees per side.
I'm at the point where I have a good, narrow edge at 20 degrees on the left side, but the right side edge (width of the edge being ground) is about three times as wide as the left side and the stone overshoots (misses) the actual blade edge by as much as 1/16th of an inch.
I'm not sure where to go from here. Do I keep grinding the right edge until the stone will actually start sharpening it? or do I need to have the edge professionally re-profiled?
Thanks for any help -- Josey
