As I also own a couple Crock Sticks, I try to stick to 40° and 50° inclusive. I know there are all sort of fancy tricks for changing the angles on the Crock Sticks, but I'd rather not have to wrestle with rubber bands and BIC pens every time I go to touch up an edge. Really, it just depends on what you want to do with the knife. The harder the work and the steeper the grind... the more often you will be back sharpening it again.Thanks it looks like a good system. What would be the best angle of degrees to use?.
In my experience, the Crock Sticks are more for touching up an already decent edge and bringing it back to a respectable level of sharpness. If your edge is "used and abused" as you put it, it may require a bit more effort.
My personal preference is the Lansky Guide Rod system. Cheap, effective and neigh on impossible to screw up. It will take more time than, say, sharpening on a benchstone; however, unlike the stones... anyone can use a Lansky.
I've seen the basic systems for as low as $20, deluxe for $30. The diamond systems run about double that and make quick work of sharpening, though there are a good number of people out there who cringe at the use of diamonds for sharpening. The reason being, they remove metal quickly and leave a very toothy edge. Me? I prefer to start with diamond and then work my way into stones on the Lansky.
