So the months of abuse i've put my Izula through mean that its not as sharp as i like
before i take it to my spyderco sharp maker does anyone have any comments or suggestions.
never sharpened something I care about before![]()
I like the Smith's sharpeners you can get at Walmart. Tungsten on one side to get the edge and ceramic on the other to get the fine edge. You can also get them with diamond rods. They are fixed angel so it makes it easy. Then of you want it sharper for shaving, you can use a strop. I've use these sharpeners for a long time with great results.
Bleh :thumbdn:
I hate those things, I have always felt they do more bad than good.
But whatever works for ya I guess
Sharpmaker is great :thumbup:
If you find you are having trouble sharpening it make sure your actually removing some of the edge and not just the coating, you can use a sharpie and mark the edge, then use the sharpmaker and see if it is removing some steel from the edge. If not use the coarse stone and try to remove some of the coating by continuing to sharpen at the same angle until you start removing some of the edge.
The DVD and handbook are excellent that come with it. Be sure to check them out.
