sharpening a re-curve
Well... don't use a flat stone to do it. I heard that Spyderco Sharpmakers work real well on it. Be very careful when you drag the knife down through it so the tip doesn't scrape against the side and round out.
-Chang the Asian Janitorial Apparatus
You can use a piece of wooden dowel, .5" to 1" in diameter, with 320 grit wet/dry sand paper wrapped around it. Get some 400 grit too, and some 600 if you want a polished edge. Paint the edge with a magic marker to make sure you are matching the existing edge angles everywhere.
When I first got my Commander Dexter Ewing recommended using the 204 Sharpmaker with the rods set to 30 degrees. That worked quite well but I now use my EdgePro Apex and than handles the re-curve with no problems. Hope this helps.
"Better to reign in Hell, than serve in Heav'n"
John Milton
There are only two types of people; those who understand this, and those who think they do.
I use a V-style crock stick holder that uses round ceramic rods. I get two angle choices and have medium and extra-fine rods. I think it's made by Colorado Ceramics.
