Any rod-type sharpener works pretty well. Round or oval diamond or ceramic 'steels', similar to those used for kitchen knives, can work very well. Can also wrap some silicon carbide or aluminum oxide sandpaper (such as the wet/dry type) around any cylindrical object, like a section of pipe. The harder the cylinder, and the more firmly-affixed the sandpaper is around it, the crisper the edges will be (use edge-trailing strokes with sandpaper). The biggest advantage to doing it this way is, you'll be able to choose the radius of the cylinder to more closely approximate the curvature of your recurve.
Some narrower flat hones can also be used, but you'll still need to be careful with pressure, to avoid over-stressing the edge on the edges/corners of the flat hone (as with the Sharpmaker).
David
