BryFry
- Jul 29, 2009
I've been practicing making V edges into convex ones with pretty good results, when I decided to reprofile the edge of a modern styled Kuhkri I quickly realized that the recurved part of the blade was going to be a bit tricky. I thought about it and here is the solution that I came up with:
First I started with a 12" mill bastard file, and useing a slight curving motion I used it to file down the shoulder and get the basic shape of the new edge going. Then I switched to sandpaper, starting with 120 grit, and useing leather as backing, I worked my way up from there sharpening the main part of the blade like you would any other knife.
As for the recurved portion of the blade I used an emty can of Pringles, ( the cylindrical chip container) I simply taped sand paper along the side of the can, changing to finer grits as I went along, and finished with leather and buffing compound held to the curved side of the can.
Here is a before:
And after ...hope you can make it out ok...
Probably not the most sophisticated method but it worked for me. Maybe it could work for you guys too. Hope this helps.
Here is a before:
