Hey guys, so my small 21 came in a week or two ago, and I've been loving it so far.....
The only problem I've had with it is sharpening. It came pretty dull from CRK, so I went ahead and sharpened it.......or so I thought. No matter what I tried, I couldn't get it sharp. I went online and found a video explaining why this was, and I concluded that the problem could only be resolved by keeping at it until something happened. I started on a 2000 grit corundum stone that cuts like CRAZY. I'm not sure if it's the type of abrasive, or if the company lied on the grit, but it can reprofile s110v like it was 440c
So as you'd imaging, it only took a few minutes for me to establish a new bevel and apex the edge, after which I moved up in the grits and finished with a nice stropping. The problem was that the part of the edge from the belly forward was Butter knife dull! I could not for the life of me figure out how to get it sharp.
I've since sharpened the knife a couple more times, and each time I do it the tip area is still extremely dull afterwards, even though everything else will shave reasonably well. In fact the part of the edge closest to the handle consistently comes out the sharpest.
So my question to you guys is what tips and tricks are there for sharpening small sebs? How should I draw it across the stone to get the whole edge? And if I were to use my sharpmaker instead, what kind of stroke would allow me to hit the whole length of the edge? Curving down, or drawing straight back as it glides down the rod? Maybe increasing the angle when I get to the tip?
And one more thing..... Is there anything I need to know about sharpening CRKs s35? Because every time I screw up even a LITTLE bit, I essentially have to restart from the beginning because there will be a big old microbevel on the edge..... Is this a result of the softness? Should I ease up on the pressure to compensate? I'm not using a lot as it is, but I could definately go lighter.
