What do you need to sharpen a fully serrated Spyderco knife?
You also can send the knife back to spyderco for resharpening.
You should go ahead and get the diamond rods from the get go. The medium and fine rods will probably work fine for awhile on your new spydies but eventually you are going to have to do some heavier cutting and reprofiling. Especially if you have some other knives in your collection. The diamond rods are really essential to getting the most out of the Sharpmaker.Thanks, I do plan on getting a 204 Sharpmaker next month. I only have 3 Spydies so far but a bunch of other knives. The Lansky system I have if hard to use so I don't.
This may be derailing the thread a bit, but what is the main difference between the diamond rods and the CBN rods on the sharpmaker, I'm looking to get either for reprofiling and chip removal but don'w know which one to purchase
I never sharpen serrations unless they are damaged. I do sharpen the flat backside and buff both sides to restore the edge but I never place a stone on the serration face.
What angle do you use when you sharpen the backside Jason? Just a degree or two above flat?
With most of the hollow/saber ground blades I lay it flat like a Scandi grind and keep pressure towards the edge. Not many FFG serrated blades but when they need it I usually try my scotch brite wheel first and if that does not bring the edge back I revert to sharpening the backside just high enough to not touch the side of the blade.
