I flatten the back first.Just lay it flat on the stone ( a large diamond stone works well here,but whatever you use - make sure it is FLAT) and lap it flat. Take it to as smooth a finish as you like.I usually stop at 600 (mirror polish and Japanese edges do not go together).Go to the cutting side and set the angle at the desired pitch.Use a very acute angle,so the bevel climbs up the side 3/4 of the way up.Take this surface to 600. Flip the blade back on the back and give it a few lapping strokes to take off the back wire. Go back to the front side and lift the blade a little (about 5 degrees more than it is ground at) and give it a couple of light strokes. This sets a micro secondary bevel.Strop the blade on a charged leather strop.First a couple of strokes on the back,then a few good strokes on the front. The hair on your arm will fall off in terror of this edge ,before it gets even close to them.
Stacy
