CPP
- Sep 8, 2014
I read Joe Talmadge's Steel FAQ on this forum. Actually, I read it a few times as it is incredibly informative. In the introduction the author says:
While it wasn't the purpose of the article to address this issue specifically, he gave the example of sharpening S30V at 15 degrees to "take advantage of S30V's superior
toughness" in order to "see a large leap in cutting performance, along with the extra wear resistance." I suppose it would be possible to deduce the proper sharpening angle from this example using a particular steel's toughness as a guideline but that is much too advanced for me and would result in little more than guess work.
Is there a systematic way to determine the sharpening angle for various steels? Or, better yet, a chart by an expert mentioning the angle for different steels to achieve optimal performance?
This leads to the general rule:
To really see the advantages of a better steel, exploit that
steel in your sharpening program. If you're going to sharpen
all your knives at the same angle regardless of steel, you
might de-emphasize steel choice somewhat.
