- Aug 2, 2012
I have a Tri-Angle Sharpmaker and when I sharpen my CS Spartan which has a big belly and is very curvy or even a knife with a mostly flat back and a roundish edge, I'm not sure how to do it exactly. It's basically two separate problems, so here they are:
1) With the big-bellied knife, like the Spartan, when I try to use the flat side of the stone, the parts of the blade that curve inward only touch the edges of the stone and not the center part. Is that bad? Should i only use the triangular sides?
2) Should the blade be perpendicular to the Sharpmaker? Like, when I get closer to the tip, should the knife be tipped forward?
