- Mar 5, 2001
Once, a while back I posted re the Busse 5 and 3 (coming from a confirmed Strider fan) and got good feedback so went shopping. I have found both models at a local SE Asian Store and the fit, balance and tests are all as advertised. The only thing that worries me is the asymetrical grind and resharpening. I use the 204 at home but at work re-sharpen free hand with DMT Diafolds. Being partially edge challenged (am getting better) I am worried that trying to sharpen a Busse with two different angles may be too much of a challenenge for me and might be better off forgeting the whole thing. The Busse 3 would defininatley get a LOT of offshore, salt environment use, from cutting rope,wood,wire,thick rubber, chopping, etc. which from listening in this forum, the Busse would handle with little problem. Still it will sooner or later get dull, and due to baggage weight limitiations can not carry the full 204 kit with DMT stones so must use only the Diafold medium/fine. Am I going to be able to resharpen this style of grind without too much drama? Do some of you reprofile so the the grinds are the same ie 20deg are such? I have been told that it is the fact that the grinds are different that lends such keen cutting ability to the Busse edge.
Am just on the edge of falling under the Busse influence, but it is this last niggling problem that is stopping me from buying both knives.
Any help/comments?
Tks in advance
Barry (aka rad)
Any help/comments?
Tks in advance
Barry (aka rad)
