Hey all,
I have been sharpening challenged for the longest time and I'd like to shed that title. I'd like to get some suggestions on 2 types of sharpeners. First a sharpener that you would use when you have plenty of time and are at your desk or table with a nice, steady platform. Then a sharpener that you can put in your pack, glovebox or in a tackle box. Something that you can grab and put a good edge on any of your knives and go on with your tasks.
I have one of the LANSKY kits with 3 stones. It works pretty well but I have trouble with larger blades. I don't know how I would fare if I had to sharpen something like a 5 or 6 inch fixed blade. I think that would be pretty tough using this kit. One thing I do like about it is that I can use it to put a decent edge on my 2 bladed broadheads like my Bear Razorheads from back in the day. Do any of you use this system on BIG blades with good results? If so, I'd like to get some pointers from you.
I also have one of those ACCUSHARP gadgets. It works pretty well I guess, but the problem I have with it is that after a few passes I will get that tiny "wire" edge that I can detect with my fingernail and then I'll try and get rid of it on that side by passing it through lightly and kinda tilting the knife so that edge will make more contact and then when I check it, that wire edge will be on the other side. I'll go back and forth like that until I can finally get rid of it. I guess I need to put together a strop with some leather and polishing compound.
I'd like some better options, especially for the quickie sharpener. Is there something better out there that gives better results without much headache?
With the larger more "permanent" type sharpener, I'd like to be as economical as I can. I can't drop $100 on a sharpening system. I'd like to, but I can't. Maybe I just need to learn to use the Lansky better.
What do you use that you really like?
Thanks for your time and any help you can give me.
Nalajr
Nalajr
