Regarding marked angles on the Lansky in particular, they are only accurate as measured to the very front edge of the clamp itself. In other words, it's only accurate to those markings if the blade's edge is flush to the front of the clamp (which makes actually sharpening the blade impossible, in that position). I've used a Lansky for a long time without really being too concerned about the angle numbers. But, I finally became curious enough to take some measurements of the three sides of the 'right triangle' formed by the clamp/hone/rod/blade, then used a trig calculator to figure the actual angle. Any blade's edge which extends further out from the front edge of the clamp, will reduce the actual angle to something less than what's marked on the clamp.
An example, I use my Lansky to re-bevel a lot of traditional pocketknives, most of which have blades that are ~ 5/8" wide or narrower. I use the notch at the front edge of the clamp to hold these blades, so there's usually ~ 3/8" - 1/2" of blade extending beyond the clamp's front edge. Taking that measurement into account for the 'base' of the right triangle, the actual angle usually works out to ~ 14-15 degrees per side, when using the '17' marked setting. Wider blades will obviously reduce that angle measurement even more. The same discrepancies exist at the other marked settings (20/25/30) as well.
So, in a nutshell, any blade which is positioned in the Lansky clamp to allow the hones to actually contact the edge, will always result in an actual angle that's less than the marked setting would imply. For very wide blades, such as kitchen/chef's knives, the angle will be much, much more acute than the marked indicator, perhaps by ~ 4-5 degrees or more per side.
For small blades, such as found on pocketknives and most typical folders, the variation in angle along the edge's length isn't going to be significant enough to notice anyway. That 'arc' which the hone works in, won't make enough difference in the distance between the back of the clamp and the edge, to make a noticeable difference. With somewhat larger blades (> 4"), you might begin to notice some widening of the bevels, the further the clamp is from the ends of the blade. Even then, it doesn't mean the edge can't or won't be wicked sharp when you're done (assuming you've properly done your part). This is why I've never been too concerned about the actual angle measurement. It's basically a moot point for 99.99% of anything we will ever use our knives for. Sharpen the edge, use it, then go a 'little higher' in angle if the edge isn't durable enough for you. Or a little lower, if it doesn't slice quite finely enough for your tastes. Otherwise, it's all good.
