Sharpening Choil on 110/112?
Lenny
Anybody put one on theirs?
How did you do it?
Pix please?
Thank you.
How did you do it?
Pix please?
Thank you.
Yes.
Here's my 110LT and my new 505, I do this with every knife that doesn't have one.
To do this I just use a little round diamond tip bit in my dremel rotary tool, but you can also use a diamond needle file or a piece of sandpaper wrapped around a small steel rod or screwdriver...etc
I have also used a rat tail chainsaw file when I'm okay with a slightly larger sharpening choil, I don't have any fancy steels so it goes easy and takes no time.
I've thought about it. Ultimately, I've taken a diamond file to it to create a sharp 90 degree angle to the plunge line. That allows me to take the stone to the very rear of the edge bevel without screwing it up.... If that makes sense.
I add a very small sharpening choil, only as deep as the edge bevel.
I use a 4 inch angle grinder with a cut off wheel and a very light touch.
I have used that method as well, and have used a dremel cutoff disk too.
Since I have a few different sizes of the diamond grit bits I use them now, but I've done it enough that I can usually do fine with just about every method.
Are you talking about a perfect 45° where the edge meets the riccaso?
I'm taking about that little spot where the factory sharpening belt leaves a little radius. Instead of cutting a notch, I just file that radius as flat as I can get it to match the rest of the edge bevel. That way the edge doesn't get hung up on the stone at the beginning of the sharpening stroke.
It sort of eliminates the reason for that sharping notch, for me, but your mileage may vary
I can try to get a before and after pic since I'm probably not explaining it very well.
J Jeff O has it figured out. That little curve is my pet peeve. It will ruin the corners of your stonesand/or lift the edge off the stone. They start like this IMG_1863.jpeg
Which eliminate that sweep at the Ricasso and any recurve. Ultimately it ends up like this IMG_4376.jpeg
Perfect is no choil no recurve perfect crisp 90* at the Ricasso
Thanks, Eveled. That's exactly what I was trying to articulate. That little recurve drives me nuts.
I use a small diamond file to clean it up. I suppose a guy could use a small triangle or round diamond file to cut the notch if so desired.
In fact, after this thread, I might cut a notch in factory-blem 112 I've got. Just to see how I like it.
Maybe I'll file it in like a tiny double-beveled serration. That way it'll still cut string instead of just catching on it.
Ok, here's what what I came up with. I used a diamond round file with the blade clamped in a vise, between two pieces of leather. I finished it with some 320 grit wrapped around the file handle. It looks like it could have come from the factory that way.
Sorry, my file skills are better than my photo skills, in this light.View attachment 2491039View attachment 2491050
Sorry, my filling skills are better than my photo skills, in this light.View attachment 2491039View attachment 2491050
Man, great work.
A little large for my taste, but it looks great. It is very Buck like reminds me of the choil on a 119 Your file skills are top notch.
Don’t go any farther back with it, on a folder part of the ricasso is also the kick, the kick regulates how deep the blade folds.
This brings up another point about choils. It is better in my opinion to not have a factory choil, so the end user can make the decisions to add one or not, and how large or small to make it.
I think you mean “down”, right? He can bring the choil back to the spine and not impact the kick.
Sorry for the confusion. It’s a matter of perspective I guess. Up down left right.
He already filed part of the kick. The kick is the highest point on the edge of the Ricasso between the choil and the bolster.
Thanks for the kind words.
It was a little bigger than I would have liked too but I followed the radius that was there from the factory. I feel like if I used a smaller file, the smaller radius cut into the larger radius would have looked awkward. Ultimately I wanted the apex of the curve to be right where the edge meets the ricasso. I got pretty close. It was fun to experiment on 20 dollar knife.
As far as the kick goes, it's untouched. It stops the blade in the exact same position.
It came out great! It’s fun to make a pleasing modification.
If you messed it up Buck would put a new blade on it for $10 (last I checked). So one way or the other it was cheap entertainment.
I usually acquire “preowned” knives and they all have those little recurves that cause the sharpener to hang up. I usually try to “flush” it up or cut a tiny notch to make sharpening easier.
