D2 is pretty fussy / needy in the refinement steps. The huge chromium carbides in D2 will tend to blunt or round the edge unless the abrasive can very cleanly thin & shape them, or if technique (steady angle control) is off a bit. Diamond will work best with D2 in the finishing stages, for the sake of cleanly cutting & shaping the carbides at the apex.
For initial grinding to set a new bevel, D2 responds very well to SiC or diamond (CBN should work too). Technically, a good AlOx stone can cut the carbides too - but I've found either SiC or diamond makes it much, much easier.
With the Sharpmaker at hand, I'd just stick with the diamond rods all the way through - skip the ceramics for finishing. If you want more polish beyond the 600 diamond, some diamond compound on a hard strop of wood works very well for that, at 3-micron or finer.
