Ok, I found a decent way to sharpen the La Griffe.
First you need the crappy plastic <a href="http://www.dmtsharp.com/products/detail.php3?use=14" target="_blank"> DMT Aligner tool</a>.
Then you need a <a href="http://www.jewelstik.com/HTML/jsknifesharpener.html" target="_blank"> Hewlett 1-2-3 JewelStik</a>.
Magically, the crappy DMT Aligner happens to fit the 0.125" width of the LG well, and the steepest (widest) setting on it happens to match the weird angle on the LG.
The easy part: Screw the rod from the Jewelstik in, and you can sharpen away.
The hard part: The curved top of the LG, combined with the curved Hawkbill, means that you have to keep adjusting the position of the clamp on the aligner in order to keep the edge angle the same. Additionally, the area of the Jewelstik hone that you use seems to change the angle. Since it's an oval-ish edge, if you sharpen along the middle, you'll get a slightly different angle than if you sharpen near the "vertices" or "corners" of the hone.
If you're careful, you can put a nice pointy tip back on it, too. Just don't roll off the tip; instead, place the tip on the middle of the oval area of the sharpener, and sharpen straight perpendicular to the tip.
I finished off the edge with a couple passes on a Spyderco-style ceramic stick.
I managed to get my LG to pretty decently sharp this way. At least now it cuts paper cleanly, and the tip will score paper with very minimal pressure.
It's not perfect, and not nearly as good as a conventional blade, but it's a working edge.
Both of these items can be purchased from your favourite store; I managed to get one from Brian@DiscountKnives, and the other from Fred@KnifeOutlet.
Hope this helps!
-Jon
Hope this helps!
-Jon
