- Dec 10, 2015
For best results cutting demos of water bottles, ropes and tatamis what works best? Highly polished, coarse toothy edges or middle of the road? What's grits to use? What about fully serrated edges?
What about the blade in question, it's geometry, steel type, and sharpening ability of the user?
As high as you want, competition cutters are all about push cuts.
I figure I should add that you should experiment with bevel angles, straight bevels vs. convex and level of polish. Your steel might go under 20 DPS without damage etc. Best is to slowly reduce angle until you have edge failure and then slightly thicken the edge, your accuracy will have a significant effect.
My skill isn't remarkable but passable I guess. I have a lansky and a cheap india stone. Can get a shaving, edge on both. My main cutting knife now has a lansky 280 grit edge at 20 deg. It will pop hair, push cut receipt paper and slice newsprint and soft tissue paper. But won't push cut newsprint. Should I go higher polish?
I saw a special recently but cannot recall the station etc. To illustrate in part Jason's statement above, a gentleman whacked through a rolled tatami with a fairly dull viking-pattern long sword.
For "trick" cutting I'd imagine a mid to low 20s inclusive and a polished edge with thin stock behind the edge. After that, practice.
I watched it on youtube. Another one cutting bamboo but same guy Quite amazing I must say considering the sword was really blunt.
Anyway I have 20 deg per side 40 inclusive bevels now. I want to test with it first before going to 15 deg. Not into competition just sharpening my own cutting skills. Knife is only basic O1 tool steel not supersteel so I don't want to go lower than 20 deg and roll the edge on chopping.
