- Dec 2, 2001
I hope this is the correct place to post a question like this, it seemed to me that some of the testers (or just technical knife nuts) here would know.
Years ago I went to a company that sharpened blades to drop off a diamond blade. This place sharpened everything from scissors to cutter heads for milling machines and who knows what else. On a huge machine in the shop was a ~5' long blade being sharpened. It was mounted in a jig and was being stroked across a stone by the machine. I later found out this was a blade that goes into a hydraulic press for cutting paper. I've always wondered about the particulars of a blade like that considering how high the pressure is when it's forced into a big stack of paper. I did some searching on the net and found out these kinds of blades are made from some typical knife steels (52100 and D2) as well as other not so typical steels and tungsten carbide.
Seeing as how the steel doesn't seem to be too much of a factor, (correct me if I'm wrong) is there a way to sharpen or even bevel a blade to optimize it for push cutting? The blade I saw in that shop looked almost like a planer blade, it was chisel ground.
