- Apr 29, 2002
(raises hairless arms)
I've started to get the hang of sharpening blades. I'm not using a sharpening system, just a set of 3 natural Arkansas oilstones. I'm using honing oil, since the stones were impregnated with oil at the factory.
In my attempts to get "hair-popping" sharpness, I've noticed a few things, that I'm not quite sure about:
1. I only have production knives, and it seems that the cutting edges on the right side of the blade (the side you don't normally see when you're slicing) are at a shallower angle than the left side. I think so because the sharpened edge is wider than on the other side by one or two millimeters. Is this generally true? Right now I'm sharpening the right edge at a higher angle than the left.
2. How is "hair-popping" defined? I think my early attempts to achieve this failed because I wasn't shaving properly.
I held the blade perpendicular to my skin, and not much hair was coming off. I realized that shaving razors are at an angle to the skin, so I tried angling the blade, and *pop* there goes all my hair. Hehe. Now I gotta test on my legs.
But when I run my finger along the edge, it feels a little "rubbery", like the blade is sticking to the skin. Does this mean my technique is bad, and there's little imperfections in the edge?
3. I noticed a good way to "see" the wire-edge when sharpening is to hold the knife so that it's facing a light source. Places with a wire-edge will cast a very small shadow along their length, so you can tell where you need to sharpen some more. This also lets you see where the angle of sharpening is inconsistent.
4. I read in a thread here that Spyderco blades are ground at 20 degree angles, I was wondering if particular companies have their own consistent grind angles.
Wow, long post. Sorry for the long-windedness.
I'm just a happy newbie sharpening all the blades in the house.
