Cliff Stamp
BANNED
- Oct 5, 1998
By heavy use I mean hours of chopping, so thousands of chops on thick brush and woods. I recently sharpened my old style Battle Mistress which had been used extensively clearing some land and limbing some felled wood. The edge could still slice newsprint but had no push cutting ability on the paper and there were some issues with cutting light vegetation. With the edge formed with a large 800 grit waterstone, the burr was easily visibly by eye and very ragged. This is a sign of a heavily fatigued edge which is common on large chopping knives which are heavily used. You can't remove this cleanly by alternating sides, it tends to crack and tear away the edge.
The knife was given one light stroke into the edge with a 1000 grit waterstone to grind down the weakened metal. The edge was reformed with the 800 grit waterstone and there was no visible burr and just a light one about 0.1 mm wide under magnification. Another pass with the 1000 grit waterstone was used and then the honing with the 800 repeated and the edge formed clean. The polish was then refined on a very fine natural chinese waterstone. This heavy initial burr formation can be prevented in many cases by sharpening more frequently to prevent the fatigue, usually only fine stones are needed unless the edge gets damaged from inclusions. The same general method works well to obtain a very high sharpness edge on heavily used machetes and such.
-Cliff
-Cliff
