Hello,
I am having trouble with sharpening. I am using a combination of Lansky table mount for angle guidance and combine that system with DMT Diamonds from my DMT alignment kit. The result is perfect when I am done with 1200grit diamond.
The trouble starts as I go to higher grits. I have mdf pieces cut to fit DMT aligner (exact width, length, shape as the diamond inserts) and I use DMT Dia-Paste on mdf pieces. (6, 3, and 1 microns). I perform the same technique I use to sharpen with coarser grits. The result is a mirror finish. The problem is that the blade doesnt slice as well as it does with 600 or 1200grit sharpening. It does however shave better. Shaving and slicing are two different things. I want my blades to slice extremly well in a way that I should be scared to move my fingers on the edge with no pressure.
I also tried lapping with chromium-oxide (0,5 microns) spread on leather; same result.
Either there is a problem with my lapping technique with leather, or sharpening technique with paste.
Or maybe shaving and slicing are two different applications.
Please instruct me on how I can get scary sharp edges on my hunting knives.
