I would prefer the coarse/fine as it would be more versatile than the fine/xfine. You shouldn't have trouble getting very sharp edges with coarse>fine>strop.
Is the lansky system actually a lot easier than freehand?
That works for me. It's what I use for 99% of my sharpening. Just picked up a coarse (red, actually)/fine (green) 10" DMT for Christmas (I have been very good). I've used the 6" bench stones for a couple of decades and they still work perfectly, but the larger size is better for honing longer blades.
Would a double sided dmt coarse/fine stone followed by a knife plus strop be good enough to get very sharp knives? Or should I get the fine/extra fine stone
To answer the op, a coarse stone will get you a sharp edge but it will be very toothy and not refined. After that a fine stone will smooth it out but it will take a while. My opinion is to get a coarse, medium and fine stones and a strop. That will set you up to get a nice clean sharp long lasting edge
I don't know you, or how well you sharpen. I am not an expert either... I think the coarse\ fine combo would serve you well. Many custom makers finish with a grit like a dmt coarse. The fine stone is refined enough a majority of people and steels. My advice would be this combo and go so very, very lightly on those dmt plates.
I get a lot from Jason's posts and and he stated he regularly reminds himself how lightly he needs to go when using diamonds. That simple sentence I read improved my work with dmt by an easy 20%. I hope he posts here, and I would listen to what he says. Have fun and good luck.
Russ
Would you place m390 in this group? I am loving this steel and am trying to find tune my sharpening routine for it. (Sorry for hijack of thread...)I have a full range of DMT Dia-Sharps that I have used for about 8 years now. I've switched to waterstones for my finer sharpening needs but still use a Coarse DMT for a lot of my knives and for my customers that use premium wear resistant steels.
I don't like to go past the Coarse DMT on high alloy steels because I find it to be the best edge for that type of steel.
