Or you can give my approach a try http://youtu.be/l2ynSDYEUYI
No pun intended. All the advice and tips have helped me...shrink my burr. That is all I have been able to accomplish. I guess that it is sad because I thought I might control the burr for once. But it is just smaller and still robbing me of sharpness. I can still see the burr under strong light but it is very hard to feel. Maybe knives just don't get sharp like I think they should be able to.
If the burr is hard to feel, you're ALMOST there. At that point I drag it across some newspaper. The non burr side will slide smoothly while the burr side will drag slightly. Try ONE light (almost no pressure) stroke on the burr side. If the burr remains on the same side, repeat. When the burr finally starts flipping from side to side, it's ready to strop. Once I get it as sharp as I can, I strop a few times on newspaper. Don't overdo it on the stropping. Two or three light strokes should do it. Good luck, hang in there and try not to get discouraged.:thumbup:No pun intended. All the advice and tips have helped me...shrink my burr. That is all I have been able to accomplish. I guess that it is sad because I thought I might control the burr for once. But it is just smaller and still robbing me of sharpness. I can still see the burr under strong light but it is very hard to feel. Maybe knives just don't get sharp like I think they should be able to.
I wasn't trying to imply that your technique was bad. I was just suggesting a way that I have used to get very good *FEEL* feedback. When you use two hands, where do you put the fingers of your off hand? The hand that is not holding the handle.
You say your bevels are "wrong". Do they look consistent? I mean several things:
1. Are your bevels even from heel to tip?
2. Are they the same on both sides of the knife in terms of bevel width?
3. Do your bevels reflect light cleanly showing one reflected line, or do you see several facets reflecting light?
I suspect you might be not giving yourself enough credit. If you *just* have a problem deburring, there are many techniques to try. If your bevels need work, that's a different problem, but one you can get past with better technique.
Sharpening is "hard", but it's also easy. We tend to over complicate it here because we are all insane enthusiasts.
Brian.
