I'm having problems getting my knives sharp using dry stones. I have a crkt ripple 2 with acuto+ steel and a gerber bear grylls compact scout knife which i assume is 440 stainless.
They are both easy to get feeling rough when i rub my thumb on them. I'm not sure if that is a burr or me just mangling the steel. Either way, no amount of sharpening gets them cutting hair off my arm or slicing cleanly through paper.
I'm using the two stone kit from razor edge systems, which a well known knife/tool guy said should easily be capable of that sharpness with a pocket knife.
I start with the coarse stone and have tried moving the knife like I'm slicing off a layer of the stone until the blade feels like it has a burr. Then i switch sides till a burr forms again on the other side. Then i move to the fine stone and repeat the process. Finally, slowly lowering the number of slices, alternating each side until i do one slice per side a few times. i've tried slicing forward, rotating the blade, back and forth motions, each time using that method the entire time. I've marked the blade with a sharpie and worn it down seeing that i am removing the sharpie well. But no matter what i do I can't seem to get it sharp.
I have briefly had it shave hair one time a few strokes but it dulled almost immediately, so i assume i shaved with a burr and the burr was bent back. But i can't easily get that each time. Not sure. I used a blade guide that came with the set also, but similar results.
I've tried different angles, and i really do believe I'm pretty consistent. But am i doing something wrong? Pushing too hard? Not hard enough? I've watched countless videos and read articles and i have no idea what I'm missing. I can only guess my angle is wrong or inconsistent, but i have no idea how to know or fix it. If an attached guide isn't working how can i get more consistent than that?
Any help would be greatly appreciated. I can probablt post a video of my sharpening attempt...
