Thin behind the edge generally means sharpening is made easier, and that's a good thing.
If anything, I'd suggest avoiding stones that are too coarse. A thin edge doesn't need a lot of metal removal to be sharpened. Tailor your sharpening habits on these knives to hones that aren't as coarse as you might use on something thicker or heavier - a 'Fine' instead of a 'Coarse', for example - and you'll likely never need an extra-coarse stone. A thinner edge also means you shouldn't need as many sharpening passes to get the job done. So, don't overgrind. Watch for burr formation to tell you when it's enough. Keep the touch light as well, as a thin edge is more prone to damage (rolling, chipping, etc) if pressure is too heavy.
Thin edges are mostly all about going finer (grit-wise), lighter (pressure-wise) and shorter (time-wise) to get the job done.
