sharpening La Griffe
can you sharpen the La Griffe with the Spyderco Sharpmaker? Anybody tried it?
lifter
Phil. 4:13
Dave
Wharton,NJ
Lifter,
The sharpmaker is definately the thing to sharpen the Le Griffe. I use a black felt pen to color the sharpened edge in so that I can find the right angle. Do several strokes on the primary bevel to develop a burr. I simply hold the blade almost flat on the opposite stone and stroke it lightly a few times to remove the burr. This might take a couple of cycles but, it will work .
Godd luck. Let us know how it works out.
Derek
Derek has it right. Another way to go is a fine DMT rod. I usually start with this and then go to the 203.
If you are brave, you can change the angle of the edge quickly with a Dremel and a hard stone. I did this to mine. I changed the angle to where the La Griffe matched the 203's angle exactly. Then you don't have any guestimation on how to hold it.
If you can't dazzle them with your brilliance,
baffle them with your BS.
