Sharpening "machines"
tcc
Currently have the Shallot combo blade, Ener-G II, and Blur (plan on getting more :D) and a couple of Japanese knives used for cooking.
Between the Spyderco Sharpmaker and EdgePro Apex which is better? I know there's a huge $$ difference but if it can be justified I may just bite the bullet :D
Also, I'm a noob at sharpening and have only used those ones where you slide/run the blade through a "V" like device.
TIA
Hey tcc,
Most of the sharpeners with a "v" that you pull the knife through can tend to remove quite a bit of metal. In my opinion, if you have a knife that has been severely neglected and really needs an edge to be rebuilt, it's ok to start with these, but after that, for regular maintainance, I think they're just too destructive.
If you touch up the edges on your knives often enough, you don't need to be that agressive. I would recommend the sharpmaker. It's easy to get good on it and it does the job right. Also, rather than buy any sharpener that uses a pull through method on carbide cutting heads, I'd suggest investing in a set of diamond coated rods for the sharpmaker. Just as easy to use as the ceramic stones and they do a fantastic job of putting a good working edge on extremely dull knives.
There are so many options out there that it can be dizzying trying to figure it out, but I know very few people who can't successfully sharpen on the Sharpmaker, so I think it's a good place to start.
Good luck with it, hope this helps,
Jon
Sometimes the Sharpmaker doesn't take off enough metal, like the first time you re-bevel a new blade. Now that the price has dropped to half, I plan to pick up those Sharpmaker diamond sticks.
:thumbup:
Thanks guys for your advice. I think I'll p/u the sharpmaker. As the EP would be good to have, I can't justify the $$ for the amount of use I would put it through. Maybe later on when I have more knives :D
I saw a Lansky sharpening system (pic). Seems like it's "almost" like the EP.
Anyone have an opinion on this?
btw, what angle is the blade on the above knives....40 (20/20)??
If you like that one....don't get it.(JMHO) Get the DMT aligner kit. DMT makes
the best diamond stones and they last a lot longer. It's what I use and
I love it. I've had it about 10 years and the coarse stone is just now about
to need replacing. I re-profile all my knives so the coarse has seen a lot more
use then the medium-fine-Xfine. Also take note, a lot of these guys here
wouldn't trade there sharpmaker for anything. If you're a noob I would learn
to free hand first. You want always have your jig in your back pocket but
you can carry a diamond/ceramic rod/stone anywhere you go.
With that said, just go with what you think will serve you best.
sharpmakers are perfect for kershaws. all of my edges are either 20/20 or 15/15 because of the sharpmaker and reprofiling is easy with either the diamond rods or the medium grit rods.
plus its priced right and comes with instructions and a dvd to teach you how to use it.
As always, sharpening BEFORE they are completely dull will give you better results, with any sharpening system.
:thumbup:
I've got the lasnky pictured above, and the sharpmaker. Due to shipping companies that suck, I got them both on the same day.
I used the lansky once.
I've used the sharpmaker every week since I got it. I highly reccomend it - I now sharpen all of my knives and friends/family knives on it. It's just so simple - especially if you use it regularly...it'll keep you splitting hairs.
Thanks guys. Although I REALLY want the EP, I picked up the Sharpmaker. Watched the dvd yesterday and now am ready to sharpen all my knives. :D
