- Sep 20, 2019
when im sharpening should i press harder and do less strokes or press lightly and do more strokes?
Neither and both.more pressure and less strokes or light pressure and more strokes?
I think the question is more nuanced than that. I take it as assuming you are using the right stone and asks how do you use it?Instead of pressing the blade down hard on the stone I use a coarser grit stone. If you do not have a coarser grit, it's going to take more strokes. There is no substitute for using the right tool for the job.
Depends on the conditions as others have stated, and there are many pressures between light and heavy.
Also, I think it’s important to consider yourself. Even when “heavy” pressure might work well, how long are you going to have to apply the pressure and for how many knives? Some people’s bodies (or techniques) do not tolerate prolonged periods of intense grinding. Versus will it take forever to grind the knife at a lighter pressure? Either way you may have to change up the pressures, the stones and/or take breaks. (Obviously too much pressure can ruin a job at a particular stage, and/or you may not have forever to do the job so you have to dig in more and suffer later—or pass on the job.)
As said, it depends.
I use heavy pressure on silicon carbide stones to hog off metal, like for thinning and setting the bevel. As I reach the apex, lighten up drastically and switch to diamond.
For touch ups, it's diamond only and very light pressure.
So... silicon carbide reprofiling heavy pressure, diamond finishing light pressure.
This is the fastest way I know to get the results I want.
On knives used a lot, deli & meat market knives I take it to the coarsest stone I have, a 80 grit SiC and use plenty of pressure while setting a new bevel and creating a burr. (We don't use knives here like they do.) Remove the burr and on to the fine to finish it off. If you don't use the coarsest stone and pressure then you'll take more time getting the job done. DM
The reasons I’ve heard are (and I’m not agreeing or disagreeing):This is almost exactly the way I sharpen, too, after much time-consuming trial and error trying different methods and stones. The only difference is that I form a burr with coarse silicon carbide to make sure I've reached the apex. I've read there are disadvantages to that, so I am not disagreeing with jpm2.
I totally agree.
I've often wondered why people take so much more time than they need to reprofile or sharpen a knife when they could do it a lot faster by simply going to a lower grit stone.
If I'm in a hurry, I'll do full length burr with the coarse stone, but the second I start detecting it, I'll lighten up to reduce flexing the edge. I'm more concerned with damaging the metal behind the apex by bending it back and forth with heavy pressure. The thinner the edge and/or lower the angle, the greater the chance of this happening.I totally agree.
If the scratch pattern it too deep, they waste time on higher grits trying to remove it; sometimes the friction is too great to deal with for an extended period of time; related to the first, if the blade is very thin with low edge angles (possibly needing a highly refined edge), the coarse grit can rip up the edge and remove too much metal—esp. softer steels.
Finally, I’ve seen some steels chip with coarser stones.
That's why it's good to define terms in a discussion! You finish where I typically start. (I hope to not go below DMT 320-600 and may polish up to 60K.)I also might have to remove a lot of metal if I had heavy edge damage but I only buy high quality knives to help avoid this problem, and try my best to make sure the edges I put on are tough enough to prevent damage. After reprofiling, unless I'm just touching up the edge with a higher grit (in my case, around 400), I usually first sharpen with a Razor Edge Systems or Norton Crystolon coarse stone, which are around 120 grit, then finish around 400 with a diamond plate.
