- Feb 11, 2008
I recently bought a bhk bushcrafter what grit sandpaper should I used to touch up the convex edge
Thanks :thumbup:
Thanks :thumbup:
It depends on condition of the edge. Try 1000 first, if it is already fairly sharp and has no visible damage. Go for higher grit and/or leather strop to polish the edge. Go for lower grit, if blade is dull.
Just experiment with it and you will understand what should you use.
Problem is I don't have a strop anything else I can use
Thanks :thumbup:
The basic idea is, if you're not sure where to start (what grit), start at the finest and work back down to coarser grits, in 'baby steps', so you won't remove any more steel than is absolutely necessary. It won't take long at all to develop a feel for what grit you need, based on how your edge looks.
