- Nov 25, 2010
Hi everyone!
I am new to the forums and I can use all the help that I can get. My gf got me an emerson cqc-14 last year for my birthday and I have been abusing it quiet a bit. Now, when it comes to sharpening, I am a complete amateur. I purchased the Lansky Professional Sharpening kit for about $29.99 (I am tight on budget). It comes with a 120,280,600, and 1000 grit coarse stones. I mistakenly believed that the "conventional v-grind" was referring to the actual edge grind and not the bevel....being the idiot that I am, I began sharpening with an equal number of passes on both sides starting with the 120 grit and working my way up to 1000 grit. Another thing that I failed to realize was that the factory sharpening angle was around 25 degrees (I think) and I was working at 20 degrees.
The blade is REALLY REALLY dull and I do not know how to fix this. I started to sharpen the ground side with 20+ passes (and 1 pass on the back to tame the burr). Even after stropping it still isn't anywhere near being sharp (I can use most of my body weight on the blade and not have it cut me...)
Here are the specs of the knife:
http://www.emersonknives.com/ekCQC14.php
Its 154cm steel, do I need Diamond hones? Are the coarse ones not up to the task? Any help would be appreciated!
Thank you soooooooo much guys and gals and I look forward to hearing from you!
