If for whatever reason, you want to sharpen on stones, vs using a jig, I think it's a great idea to get one of the jigs also. Either make a set of crock sticks form the leevalley.com kit, and make them to whatever angle you like. Or get a spiderco or galcho set of sticks, coarse is sorta what I have in mind. Or get one of the units that holds the knife in a vise, and aligns a stone on a wire (real easy to make your own also). With this set of training wheels you can get you bevels back to flat if your sharpening rounds them over. When they are flat do the next couple of sharpenings freehand, eventualy the stretch between needing the jigs will get pretty long.
If you just want to sharpen a knife, get one of the jigs right off the bat.
When sharpening a knife with a flat bevel, put the knife on the stone, and roll it towards the edge. Just as the bevel flatens, a little skirt of oil/water will emerge rapidly, which is a good tipoff that you are lined up.
If you start with the knife tip off the stone and imagine the edge at the point has a section 90 degrees to the main part of the blade (extreme tanto). Then when you finaly got around to sharpening the tip, the main part of the blade would have lifted up to your bevel angle, gone from 0 degree flat, to say 22.5 degrees.
One way to visualize this it to put stone at the 22.5 degree angle (or whatever you are using), just like half a crock stick. The starting position for the blade will be with the main part of the edge parallel to the floor. And with the centerline of the knife on a plane perpendicular to the floor. place the edge in this position on the inclined stone. Move the edge slowly down the stone, until you are working the tip. In this position, the main edge will no longer be parallel to the stone, but at 22.5 degrees (or at least moving in that direction, since yuo probably don't have a knife with the tip rise I mentioned). This 3D swish, so easy to see in this orientation , is just what you have to make happen when sharpening the edge with the stone flat.
