SHARPENING EMERGENCY !
Ohhhhhh . . . SHARPENING EMERGENCY !
Coming through . . . coming through.
(At least that's what I told The Chef to get out of washing dishes right now.)
Don't stand back !
Don't give it any air ! It'll rust.
What seems to be the problem here ?
Oh . . . saw teeth, dull saw teeth oh well . . . it's just a little bur the patient will live.
Looks like I got to you just in time though. Saw teeth should be sharpened with . . .
with. . .
saw tooth files.
No, no . . . I know it sounds crazy. Fantasy time right.
Here allow me to demonstrate :
I tested one of the triangular SAW FILES on the spine of the Opinel; see the glints where I took off the fire steel scraping edge near the point and near the pivot end of the blade. Files will act as pointers from now on.
Then it was time to see if the edge was harder than the spine. See the file width glint on the edge. It did in fact feel a bit harder. The heat treat on this particular blade was first rate by the way. I cut a big old slot in the blade all the way across and I still had to bend the blade ninety degrees like six times before it finally snapped off and that was while it was held in a vise with big channel lock pliers on the part of the blade you see here.
In any case if you can't get in the slots with the Western style saw tooth file there is always the Japanese saw Feather file shown; gets in them rather more aggressive toothies !
Ok now I think you will be fine after some retail therapy.
That was touch and go for a while there.
Dishes . . . no not right now dear . . . I have some follow up and paper work to fill out on this one . . .
