I had a 1095 steel blade that I chipped earlier this year. It took about 2-3 months of touch-up sharpening to remove, going back to 320 grit and up to 1000 (Edge Pro Apex). I was not concerned about the chip, I wasn't going to grind away at my blade just to remove it otherwise I would have dropped down to 220, or if I got crazy, even 120, the night I got home with it. The thing is with the lower grits they remove metal exponentially faster. I just opted to keep the blade sharp, not worry about the chip, and eventually the chip went away.
If it really bothers you then grind it out. You'll need a way to take off more metal though, and a lower grit wet stone would be a good place to start. Or, sent it off to have it ground out. I would venture to say anyone that sharpens will match the angle you have, unless otherwise requested.
