Hello everyone, im new here. I manufacture knives for cutting plastic jugs and bags only, in the agricultural industry. I am looking to get some insight on how to better produce my blades. I will go through a couple thousand blades in the next 6 months and the method of belt sanding each blade multiple times is taking a tole on my shoulder. The parts are of 316L Stainless lasered out of 12 gauge sheetmetal. The reason for the lower grade is for weldability. The blade edge is straight with no curves with a cutting edge length of 12". I use a cnc mill to create the basic profile of the edge which is fairly sharp already but I go through and sand each one 50 grit, 220 grit, then a final leather strop with black compound. This works great on creating a sharp edge to cut plastic jugs that last years but large scale production wise is awful. I am looking at setting up an automatic surface grinder with a fixture setting my blade to be ground at 25 degrees. With how well the milling works I think I will only have to take off maybe 5 thousandths to get a good finish. My question is grinding on a fixture in a lateral reciprocating motion with coolant I will be grinding parallel to the edge. I am hoping for a glassy finish from the grinder but I am afraid this parallel grind could potentially cause wear issues. I plan to still leather strop all of them with compound after grinding so to the naked eye you shouldnt see any scratch marks parallel to blade. Does anybody have any insight if on a microscopic level that this could reduce my blade life or cause problems? Also if anybody has input of manufacturing equipment that would work better I am definitely interested. Sanding each blade on a belt just takes too much time and does not create perfectly consistent blades.
Thanks,
Ethan
Thanks,
Ethan
