To add more about the HT ...
A file skating on the edge indicates very little. Even pearlite can skate a file. A blade at Rc50 could likely skate a file. And, conversely, a blade with decarb from a forge HT may file easily at the edge .
Yes, I do the "file test", as most folks do, but I don't panic when it bites in. Grind the edge back about .005" to .010" and it should be fully hard and good steel.
I was at a newer smith's very basic forge last year and he had just done a HT. He hit it with a file and exclaimed that the HT failed again. He said most of his HTs were easy to file the edge, and the more times he re-did the HT the worse it got. He was positive he had been sent bad steel. He showed me six knives in a bucket that were all "Bad". I took one out and went to the grinder (a HF 1X30, but it was all he had). At first it was like grinding mild steel ... virtually no sparks. A few seconds later there were showers of intense sparks. I told him he had to grind past the decarb to get to the good hardened steel. We re-ground the edge and bevels on every blade and all were fine. The other issue was he was forging the blades with a two-brick forge and doing fifty or more heats to shape the blade. With all the overheating and re-heating he had a serious layer of decarb on the blades. I explained that every carbon steel blade needed to be re-ground/sanded after HT. I showed him how to cycle the blades to repair the thermal damage and restore the grain, and remove the high amount of RA. He had much better results after that.
