- Jun 4, 2012
So I will admit that I'm pretty new to sharpening. With that in mind, I just picked up a Lansky sharpening system. I've decided to sharpen my Tom Krein k9. So far it's uses have been primarily for camping/bushcrafting. I figured for that purpose, it would have a pretty big angle so I put the rod through the 30 degree slot. to my eyes it looks flush with the angle Tom has. I then put it in the 25 degree slot. It looked pretty flush but not as much. Remember, this is just me eye-balling it for now. Then I put it in the 20 degree slot. It didn't seem flush. I then took a dry erase marker and marked the edge. My first swipe was with the medium stone on the 30 degree angle. Not too much force as I wanted to see what happened to my mark. turned out 30 degrees was too wide. I then took it down to 25 degrees. Still too wide. I took it down to 20 degrees. That ended up being the angle Tom has on this knife as it cleanly took my mark off. Going by Lansky instructions and just general knowledge, I always thought that having a narrow blade (especially 20 degrees), wasn't the best angle for chopping wood. If that angle is fine then I'll continue to sharpen it there but if 25 or 30 degrees is better, should I re-profile it? Thanks for any and all help.
