rockrewls :
... a 20 degree inclusive edge on the blade first, and then put a 30 degree edge inclusive on the 20 degree inclusive edge is this correct?
Yes, this is called using a secondary edge bevel, first used significantly by Joe Talmadge.
... isnt the 20 degree straight edge better by itself?
The small additional 30 degree edge adds a lot of durability. When edges chip or roll they do so to a very small extent, less than 0.1 mm in depth for most cutting. Even though this is barely visible, it can still seriously reduce the cutting ability of the blade.
By adding a slightly more obtuse bevel just along the edge you greatly reduce the likely hood of edge damage, and since this bevel is very narrow (just barely visible), it doesn't significantly reduce the cutting ability.
In addition, using a secondary edge bevel *greatly* increases ease of sharpening. When you apply the primary edge bevel of 20 degrees inclusing you are not really sharpening as much as shaping so you don't need to be concerned about precision nor accuracy, this is just a shaping step. This allows this part of the bevel to be applied very fast with a fairly coarse hone.
Now you sharpen the edge with the secondary bevel which gets applied very fast because of the already existing edge which is more acute. Putting a 15 degree bevel on top of a ten degree one is only a matter of a few passes per side that is all, just seconds.
When you resharpen you just hit the secondary edge bevel, after awhile it will thicken and you will need to reset the edge with the more acute bevel removing the secondary edge bevel completely and grinding a fresh edge.
-Cliff
