Conventionals are fine if they arent too wide.All my knives are straight from heel to belly, thinking of getting a new knife that has a slight recurve. Just wantng to know if you can sharpen on conventional stone or need something else? Thanks
Diamond or ceramic rods.
Recurves are a pain. At least to get to "hair whittling sharp" consistently across the blade.
Imagine holding a stone parallel to the ground (as I do...especially with recurves).
You want to take the knife and hold it at an angle...with the handle side LOWER than the stone so it hits the initial curve at the back at an appropriate angle on the corner of the stone.
As you slide down the stone and work towards the tip...you raise the angle slowly and consistently across the blade. You want to be flat on the stone at the lowest belly of the blade. Then create an UPWARD angle as you reach the tip.
Doing a full regrind like this isn't necessary really. Just do the harder work on the corner and do the curving the blade motion when you actually start sharpening...still takes more time and is easier to mess up.
It is a pain in the ass, as stated...but once you get it down it'll feel like any sharpening system you develop for yourself. You'll find your hand naturally landing and moving exactly how it should be at the correct angles...and you'll be able to do it nearly as quickly as with any knife.
I love recurves. Definitely worth the hassle in my opinion.
Use the edge of the stone to sharpen the recurve.
