Just for touch up sharpening on a small hunter or pocket knife, worksharp makes a guided sharpening system and a field guided sharpening system. Those aren’t overly expensive options. The former being slightly more expensive than the later. I have the larger guided sharpening system. It includes a ceramic rod insert that has two “grit” settings. It’s fine for touch up sharpening, but I wouldn’t try to set the initial secondary bevel with it.
If you are planning to do a lot of recurve blades it might be worth looking into setting yourself up a little 1” belt grinder that is slower than your grizz. If setting up a true grinder is currently out of reach, maybe look at the powered worksharp dealios. They have various models that would give you a basic little “belt grinder” with variable speed and grit options for about the same cost as a couple good stones.
