OK...admittedly I am a Noob with a capital "N". Most of my sharpening has been done on small knives with a Lansky rig. Results were OK, but not special. When you get to large knives, like khuks., a Lansky just doesn't cut it.
What to do? Dan Koster advised to go ahead with a good file and profile an edge. A file is a scary thought. Imagine all that metal being removed and the possibility of deep scratches as well. The failures of 7th grade metal shop class come to mind.
Well, a careful hand with a good file will produce a decent edge angle on a large blade. I did just that on some of my larger hawks and khuks. After getting a good edge angle ground, I then used a mouse pad and wet/dry paper. Use a progression of grits on this. Start at 200 grit and progress to higher grits such as 400 then 600. 600 grit only seems to polish, so you can not do much damage at this point. You get a convex grind which is supposed to be very durable. Bonus is that your wrist become very conditioned by grinding on the mouse pad in circular motions.
Anyway, until I got brave and used a file, I just could not imagine how to get my khuks and hawks sharp. A good file and mouse pad with wet/dry paper are the answers unless you have a powered belt.
A powered belt (Delta?), as discussed in recent threads, is my next purchase. The powered belt will enable me do edge profiling and handle shaping. I have some blade blanks that need canvas micarta or dymondwood scales.
Sorry if I have gone on a bit. The mouse pad and abrasive paper method was a revelation to me. Works well.
Jeff
Jeff
