PDE, what kind of steel is the blade?
I sharpen my Scandis on a 1200 grit waterstone, with the primary grind flat on the stone. I'll stroke several times (about 10 or so) on one side, then flip and do the other. Then I'll grind about 5 times before flipping, then 3 or so, then I'll start turning the blade after every stroke, easing off on pressure as I go. When the edge has attained a "crispness" - a sharpness - I go to the Spiderco Sharpmaker's white stones.
Lay the primary grind flat on the stones at the 30 degree setting. Then lean out just a tad to vertical and take 5 or 6 whisper light passes per side. What's happening here is I'll be putting the slightest of micro-bevels on the edge. Then I strop carefully with green chromium oxide until the edge is finished.
To me, the scandi grind is the easiest to get truly razor sharp.
