You need 1 live chicken, at least 1 virgin, a bowl, Black Sabbath's "Sabotage", and about 4 hours. When you get these things rounded up let me know. I will give you the rest of the directions.:thumbup:
I was going to start a thread with this a few days ago but got busy.
I marked the edge of my Warden user with a red sharpie and started with the Sharpmaker, I saw that the angle of the stones were nowhere close to the grind. So I made a tilted platform so that the stone I was using was at 62 degrees or 28 off vertical rather than 20. Even at 62 degrees (I used and angle finder that I keep around for bike frames to measure the angle) it took a ton of time with the course stones to hit the edge. But once I did all it took was about 10 swipes with the fine stone and now it is taking hair off my arm like a razor.
So basically what I did was tilt the base of the Sharpmaker platform so the angel of the stone I was cutting with was increased to the point where I was close to the factory edge angle. You just need to be consistent. What also works is to use one of the sharpmakers stones as a shim about one inch in from the end of the base. You have to be consistent and careful to place the shim in exactly the same spot, so mark the base on each end with a file or something and then flip it back and forth to work each side of the knife. Mark the blade with a sharpie and then after a few times on the stone check and see if you are near the edge, if not tilt it more or less. Remember the markings for the next time you sharpen that knife.
Last week this worked for me like a charm on several heavy use knives with edge angles is the 30+ degree range. I just made a few small platforms to tilt the Sharpmaker more or less. I use an Edge Pro if I want to reprofile.
If this isn't understandable I can post a photo.
MyMind,
Would you care to share your technique with the EZ M. I only make my SJT duller with mine.
Thanks
Thanks,
So how is the blade oriented when using the smoother side? I take it that the blade is stationary.
