- Dec 28, 2012
I have a question. If i were to buy just one sharpening stone for my sharpening instead of a set what kind and which one should I get.
What steels are you planning to sharpen with it? That could make a big difference, in terms of what you actually need. Safe bets for most steels would be something like the aluminum oxide or silicon carbide stones from Norton ('India' and 'Crystolon', respectively). Diamond might be overkill for simple carbon steels (1095, CV) and low/mid-range stainless (420HC, 440A/440C, etc.), but more useful or even necessary for very wear-resistant steels like S30V. Natural stones (Arkansas) usually don't do well for heavy grinding on anything but the simplest steels, so they'd likely be the least useful for most modern knives.
David
Right now the most modern steel I Have is vg10.
Combination Soft/Hard Arkansas stone would be good
VG-10 is pretty easy stuff to sharpen. If you aren't using other steels that are higher wearing then you should get on fine with a combination stone like David mentioned.
I'm going to assume that you aren't looking for big changes to your bevel angle, although with the coarse side of the combo stone it is certainly possible, and you aren't after a mirror polished edge either... is that safe to say?
The finish that you can achieve with a combo stone (like the Norton 6" economy sold at Home Depot for $6) is very workable based on the testing and efforts of forum member Heavy Handed. I haven't gotten that far myself, but then I haven't used it all that much. What I have experienced though has been very positive for aggression and finish.
Really dont care for a mirror polish and thanks for the help.
