Hi, I have a CRKT Ken Onion Ripple 2 that is getting dull. I've never really sharpened a knife before, and I was looking for some tips on stone purchasing and usage. Let me explain my situation so far and perhaps someone could help?
This is my first 'nice' knife purchase. This thing was 'popping' hair off my arm out-of-the-box. Very impressive to me. I've used this knife soooo much, and the blade has held an edge very long. It is Acuto+ steel. I've ben using it to cut boxes (I hear this is the worst), cut rope, peel fruit (always wash the knife after) and many other basic tasks. I try not to cut anything I think would nick or damage the blade (metal wire - no matter how thin, etc.) After half a year at least of using this daily, it is now starting to have problems easily cutting through paper. I've noticed it slowly getting worse, I started researching sharpening.
I started with a pocket sharpening smith tool that you just slide the knife through. I did NOT do this on my ripple. I test everything with my swiss army knives. This took my incredibly dull swiss army knife and made it useable, but it didn't really get much sharper than my ripple is now. I tried a few times per the instructions and videos online with different stroke amounts on the hard and ceramic sides. Always the same edge. I think it is simply meant for utility perhaps. I want hair shaving sharp. My knife held it so long, and I want it back! haha
So, through all of my research, the most affordable, most simplistic solution appears to be the Spyderco Sharpmaker. I don't have a problem with this, and am still considering it, but I'm more of a 'traditional' kind of guy, and I like stones. I like the simplicity and the traditional style of it. It also gives you nearly unlimited edge angles based on technique.
So, I have a stone my father-in-law gave me, but I'm not sure if it is good or not. Remember, this is my first time using one. I took a dull swiss army knife and put marker on the blade edge. Per a bunch or resources and videos I think I have the angle/basics down. I proceeded to sharpen the blade using the general technique of keeping a consistent angle and starting with more strokes and then alternating and lessening the strokes. I tried this with varying amounts of pressure and stroke amounts. Each time the blade got to a certain level of sharpness where it doesn't really cut through paper without rubbing the knife back and forth to start it. Once it starts it cuts the paper o.k., but I can tell it isn't a nice smooth cut.
I'm curious if this is my technique or simply a rough stone that gets the blade edge going, but doesn't really get it 'sharp'? Here are some pictures of my stone and knives if it helps.
http://www.flickr.com/photos/41884932@N02/sets/72157632727407749/
I have bad lightening in my apartment and it doesn't probably show much, but the marker came off the blade edge completely despite the lightening in the photo. You can see leftover marker above the edge angle. So, I 'think' that means I did reasonably well with my angle. So, if I were to purchase finer stones, would my current technique continue the process into forming a nice sharp edge? Or do you think the stone I have should get the edge even sharper still? I can't tell if the stone is good or not as well. It is old and "feel" fairly smooth, but I assume it's possible that it is not flat enough and is preventing the blade from getting sharper?
With all of that said, I think I probably want to get at least two stones for my main goal of sharpening/maintaining the ripple. I want a general grit to touch up the blade and a finer grit to get it hair shaving sharp. Beyond that I can refine it, but it may not really be necessary to me. I'm thinking 800/4000 stones? I have seen reviews/videos of the Spyderco "Double Stuff", and it seems to get knives hair shaving sharp. I don't know the grit level, but that is portable and affordable.
I would prefer not having to use water or oil if possible, but if not I would rather use water and not oil for simplicity/availability sake. Can anyone let me know what they think of all this and what my best stone options are? Are there any affordable stones that will do this? They seems to go upwards of $100 for two stones... Let me know if you have any questions. Any help would be appreciated!
